Ryan Lekivetz, PhD, JMP Senior Research Statistician Developer, SAS
The Simulate Responses option in most design of experiments platforms is useful for generating simulated data for an experiment. In JMP 13, we have improved the response simulator by allowing for normal, Poisson and binomial distributed responses. We also create a column formula that generates the data. This feature is even more effective when used with the new JMP Pro Simulator to do empirical power calculations. This talk will demonstrate the new Simulate Responses and how to use it to perform empirical power calculations with JMP Pro.
Published on ‎03-24-2025 08:55 AM by Community Manager Community Manager | Updated on ‎03-27-2025 09:22 AM
Event has ended
You can no longer attend this event.
Start:
Mon, Sep 19, 2016 09:00 AM EDT
End:
Fri, Sep 23, 2016 05:00 PM EDT
