Scoring Outside the Box
Nascif Abousalh-Neto, JMP Principal Software Developer, SAS
Daniel Valente, PhD, JMP Senior Product Manager, SAS
- 2x
- 1.75x
- 1.5x
- 1.25x
- 1x, selected
- 0.75x
- 0.5x
- Chapters
- descriptions off, selected
- captions settings, opens captions settings dialog
- captions off, selected
This is a modal window.
The Video Cloud video was not found.
Beginning of dialog window. Escape will cancel and close the window.
End of dialog window.
This is a modal window. This modal can be closed by pressing the Escape key or activating the close button.
- Chapters
- en (Main), selected
Scoring – the process of using a model created by a data mining application like JMP to make predictions for new data – has been called the "unglamorous workhorse of data mining." Like a dark yin to the bright yang of predictive modeling, scoring plays a fundamental role in the implementation of a complete data mining life cycle. Scoring requires that the model is first adapted so that it can run where the new data is produced or stored. This process is usually a time-consuming and error-prone endeavor. In this paper, we will see how the new score code generation features in JMP 13 can assist you in extending the reach of your models while minimizing the work required to adapt them.
- 2x
- 1.75x
- 1.5x
- 1.25x
- 1x, selected
- 0.75x
- 0.5x
- Chapters
- Chapters
