Share your analytics insights with fellow JMP users. Submit a brief abstract to the Discovery Europe call for content describing innovative ways you use JMP.
silent install
HI Folks,
     I'm trying to create a silent install for JMP 11.2.  I've created the ISS file,
From an administrative shell:
C:\11_2\jmp\Windows>.\setup.exe -r -f1c:\jmpsetup.iss
For whatever reason, when I try it with the -s switch to do the install, I'm getting this as a result in the log file...
it goes through 90% of the install the icon populates on the desktop, then at the last minute it backs out.
C:\11_2\jmp\Windows>.\setup.exe -s -f1c:\jmpsetup.iss -f2c:\jmpsetuplog.txt
what am I missing?
<code>
[InstallShield Silent]
Version=v7.00
File=Log File
[ResponseResult]
ResultCode=-3
[Application]
Name=JMP
Version=11.0
Company=SAS Institute Inc.
Lang=0409
</code>
Re: silent install
Can you post the contents of the ISS file?  I am wondering if you the prompts during the original installation are not matching what is needed on the other machine.  Also, did you create the ISS file on a PC with the same bitness as the PC you are attempting the silent install?
- Bob Hickey
- Bob Hickey
Re: silent install
HI,
    I captured the ISS file again, but this time I removed the checkmark to install java, and that ISS file seems to work.  As part of my silent installer I'm forcing in the .NET package, and all of our machines have java installed, and updated via the enterprise.
so in this case, it weas either the java checkmark that was causing it to fail. even though Java was already installed on the machine, or there was something with my capture file.  which is possible.  but..  ..
tryp
Re: silent install
I had to capture an answer file for our x86 & x64 image.
it seems that the answer file contains two lines that are different.
x86
Component-0=Program Files32
Component-1=RootLevel32
x64
Component-0=Program Files64
Component-1=RootLevel64
I am now using a vbs script to decide which answer file to use.
' -- IS SYSTEM x86 or x64
DIM WSHELL, WSHELL_ENV, PROC_ARCH, OS_ARCH_TYPE
SET WSHELL =  CreateObject("WScript.Shell")
SET WSHELL_ENV = WSHELL.Environment("Process")
PROC_ARCH = WSHELL_ENV("PROCESSOR_ARCHITECTURE")
If PROC_ARCH = "x86" Then
  OS_ARCH_TYPE= WSHELL_ENV("PROCESSOR_ARCHITEW6432")
  If OS_ARCH_TYPE = ""  Then
   OS_ARCH_TYPE = "x86"
  End if
Else
  OS_ARCH_TYPE = "x64"
End If
