Where do I find the sample data files?
Jeff_Perkinson
Re: Where do I find the sample data files?
Within JMP you can access the Sample Data from the Help menu.
That will open the Sample Data Journal from which you can open and data table.
If you're wondering where the sample data tables are installed:
  • On Windows -  C:\Program Files\SAS\JMP[PRO]\[Version Number]\Samples\Data
  • On the Macintosh - Macintosh HD ▸ Library ▸ Application Support ▸ JMP ▸ 11 ▸ Samples ▸ Data
I hope that helps.
-Jeff
-Jeff
Jeff_Perkinson
I hope that helps.
-Jeff
-Jeff
JMP Deployment Guides
The Deployment Guide contains installation and deployment options, including information on updating your license at renewal time.
Go
Article Labels
