We're Warning You: Control Chart Warnings in JMP® Live 16 (2021-EU-45MP-733)
Aurora Tiffany-Davis, JMP Senior Software Developer, SAS
Josh Markwordt, JMP Senior Software Developer, SAS
Annie Dudley Zangi, JMP Senior Research Statistician Developer, SAS
In this session, we will introduce an exciting feature new in JMP Live 16. You and your colleagues can now get notifications (onscreen and via email) about out-of-control processes.
We will demonstrate control chart warnings, from the perspective of:
- A JMP Desktop user
- A JMP Live content publisher
- A regular JMP Live user
We will point out which aspects of control chart warnings were available before version 16, and which aspects are new.
Join us to learn:
- Which JMP control chart warnings platforms are supported.
- How to control which posts produce notifications.
- How to control who gets notifications.
- How to pause notifications while you get a process back under control.
- How to review (at a high level) the changes over time for a particular post.
Auto-generated transcript...
Speaker |
Transcript |
Thank you for joining us today | |
to learn about a new feature in | |
JMP Live 16: Control Chart | |
Warnings. You may be thinking | |
Control Chart Builder has been | |
available in JMP Desktop since | |
version 10 and Control Chart | |
Warnings have been available in | |
JMP Desktop since version 10. So | |
what's actually new here? What's | |
new is in JMP Live version | |
16 we now have a way to grab | |
your attention if there's a | |
control chart post that has | |
warnings associated with it. In | |
other words, if there's a | |
process that might have a | |
problem. We do this through the | |
use of onscreen indicators as | |
well as active notifications | |
that can go out to users | |
on screen and by email. | |
I'd like to now introduce just | |
a few of the people who helped | |
to develop this feature. | |
I am Aurora Tiffany Davis, | |
senior software developer on the | |
JMP Live team, and during | |
today's demonstrations, I'll be | |
showing you JMP Live from the | |
perspective of a regular user. | |
We also have with us today Josh | |
Marquordt. Josh is a senior | |
software developer on the JMP | |
HTML5 team, and during today's | |
demonstrations he's going to | |
show you the perspective of a | |
JMP Live content publisher. | |
Finally, we have Annie Dudley | |
Zangi. She is a senior research | |
developer on the JMP statistics | |
team and she's going to be | |
demonstrating the control chart | |
features within JMP Desktop | |
itself. Annie, would you like | |
to get us started? | |
Thanks Aurora. Yes, so I'm gonna | |
be demoing this with showing | |
you how this works using a | |
simulated data set based on a | |
wine grape trial that happened | |
in California. So what we have | |
here is 31 lots, several | |
cultivars and yield, brix | |
sugar and pH. So let's start with | |
Control Chart Builder. | |
First, I'm going to pull in the | |
yield (that's in kilograms). | |
And then I'll pull | |
in the location. | |
Has a subgroup variable. | |
I don't care about...so much about | |
the limits. What I am concerned | |
about instead is whether or not | |
we have any particular lots that | |
are going out of control there. | |
Going above the limits or below | |
the limits. And I care about how | |
each of the cultivars are doing, | |
so I'll pull that into the phase | |
location, which basically | |
subgroups all the all the | |
different...or subsets all the | |
different cultivars for us. So we | |
can see that we have differences | |
and kind of unique things going | |
on with the different grapes. | |
Next I'm going to turn on | |
the warnings. | |
And to...the easiest way to do that | |
is to scroll down under the | |
control panel and select | |
warnings and then tests. | |
We're going to turn on Test 1, | |
one point beyond the limits, and | |
then Test 5 as well. | |
OK, I see no tests have failed. | |
That's pretty good. | |
And now you might recall we | |
were looking at two other | |
response variables, so I'm | |
going to turn on the Column | |
Switcher so we can look at all | |
three of them. We can just flip | |
through them using the Column | |
Switcher. | |
So we started with yield. We'll | |
take a look at sugar. Alright, | |
we can see the Aglianico has | |
very low sugar content, whereas | |
the other four have a higher | |
sugar content. And we can see the | |
different pH levels for each of | |
the five grape varieties. OK, | |
well we've got these 31 lots in. | |
I think we're ready to publish | |
it. Josh, would you like to show | |
us how to send that up? | |
Thanks Annie, so I have the same | |
report up that Annie just showed | |
you and I'm ready to publish to | |
JMP Live. The first thing I | |
would need to do as a new | |
publisher would be to set up a | |
connection to JMP Live. | |
If I go to file, publish, | |
and manage connections. | |
You can see that | |
I have a couple of connections | |
already created, but I'm going | |
to add a new one. | |
First you need to give | |
the connection a name just to help keep | |
track of multiple connections. | |
The next thing you need is | |
the URL of the server you're | |
trying to connect to, | |
including the port number. | |
Finally, at the bottom of the | |
dialog you can supply an API key | |
which says for scripting access | |
only. You only need this if you | |
are going to be | |
interacting with the server | |
using JSL, which we're going to | |
do later in this demonstration, | |
so I'm going to get my API key | |
from JMP Live. | |
I'm logged in. | |
I go to my avatar in the upper | |
right-hand corner and select | |
settings to see my user | |
settings. At the top there is | |
some information about my | |
account, including the API | |
key. I click generate new | |
API key and copy this by | |
clicking the copy button. | |
to my clipboard, then I can | |
return to JMP and simply paste | |
it in here and click next. | |
Authenticate | |
to | |
JMP Live. And you will be told that | |
your connection was created | |
successfully and you can save it | |
now. It is now present in my | |
list of connections and ready to | |
use for publishing. You only | |
have to do that the very first | |
time you set up the connection. | |
The next time you publish, you | |
can just use it. | |
So now I can go to file, publish | |
and publish to JMP Live. | |
And select my connection from | |
the dropdown at the top. | |
Create a new post is selected by | |
default. So I click next. | |
And this dialogue looks very | |
similar to what it did in 15.2, | |
except now there's an | |
additional checkbox here that | |
says enable warnings. | |
This is present for every | |
warnings-capable report. | |
If I hover over it, it says, | |
"Selecting enable warnings will | |
notify interested parties when | |
this post has Control Chart | |
warnings." I'll get back to who | |
the interested parties are in | |
a moment, but first I wanted | |
to explain what warnings- | |
capable reports are. In JMP | |
16 only the Control Chart | |
Builder is warnings-capable | |
and able to tell JMP | |
Live about warnings that are | |
present within it. There are | |
plans to expand to other | |
platforms in the future. | |
A Control Chart Builder can be | |
combined with other reports in a | |
dashboard or tabs report. | |
And it can be combined with | |
the Column Switcher as we're | |
showing in this example. | |
Some more complex scenarios | |
could cause an otherwise | |
warnings-capable report to not | |
be able to share warnings and | |
this enable warnings checkbox | |
would be gone. | |
For example, the Column Switcher | |
only works with a single Control | |
Chart Builder. If you try to | |
combine it with multiple control | |
charts in a dashboard, that | |
would no longer be warnings- | |
capable in JMP 16. | |
So back to who are the | |
interested parties? I, as the | |
publisher of the report, | |
am an interested party, | |
as well as the members of any | |
group I publish to, if that | |
group is warnings-enabled. | |
So I am going to publish this | |
report to the Wine Trials Group | |
and leave enable warnings | |
checked so that JMP will | |
tell JMP Live about any | |
warnings that are present. | |
The report will come up in JMP | |
Live. And the contents of the | |
report look much like they did | |
in 15 and 15.2 | |
The points have | |
tooltips. You're able to brush | |
and select and the Column | |
Switcher is active, allowing you | |
to explore the results in | |
multiple columns. Now I'm going | |
to hand it over to Aurora so she | |
can show you some of the new | |
features in JMP Live. | |
Yeah, thank you Josh. So Josh | |
just published a post to JMP | |
Live that is warnings-enabled, | |
but that doesn't actually have | |
any warnings going on right now, | |
so I can show you what that | |
looks like from the perspective | |
of a regular JMP Live user | |
and what it looks like is not a | |
whole lot. There really isn't | |
anything to draw my attention to | |
Josh's post. There isn't any | |
special icon showing up on his | |
post. I don't have any new | |
notifications. If I open the | |
post itself, and I opened | |
the post details, | |
and I scroll down, I will see | |
that there's a new section that | |
did not exist prior to JMP Live | |
version 16. And that's the | |
warnings section. This section | |
is here because the publisher | |
said, by checking that | |
enable warnings checkbox in | |
JMP desktop at publish time, | |
the publisher is saying, I | |
think that other JMP Live | |
users are going to care whether | |
or not there are warnings on my | |
post. And so we have a warning | |
section here. But right now it | |
just tells us a very reassuring | |
message | there are no warnings |
present. If we scroll down | |
further, we can see the | |
system comment that JMP | |
Live left in the comments | |
stream at publish time, and | |
again, this just tells | |
us a nice reassuring | |
message | this post has zero |
active control chart | |
warnings. I'll pass it back | |
to Annie now so that she can | |
walk us through the next | |
step of the grape trial. | |
Thanks, Aurora. | |
So as I said before, we're | |
getting new data in. We had 31 | |
locations before. Now we have 32. | |
The original study | |
was adding some some actual | |
restricted irrigation lots so | |
that they could find out how the | |
five different grapes responded | |
with restricted...with more dry | |
regions. So if we take a look at | |
the control chart with these | |
these restricted values, | |
we can see that the yield is | |
lower in this new...in this new | |
lot that was just added. And | |
in fact, with the Tempranillo | |
grape it is...it is below the | |
lower limit. We can take a look | |
at the sugar to see how that | |
responded and we can see that | |
the sugar actually went up for | |
our new restricted irrigation | |
dry spot. | |
The pH wasn't wasn't | |
anything abnormal. | |
So I think we need to | |
update this. Josh, do you | |
want to show us how? | |
Yes, so new in JMP 16 in JMP | |
Live is the ability to update | |
just the data of a report. | |
This is useful because you don't | |
need to rerun the JSL or | |
recreate the report in JMP and | |
republish. You simply want to | |
update the existing report with | |
new data. This can be done | |
directly from the JMP Live UI | |
by selecting details | |
and scrolling down to the data | |
section where you can view the | |
data table that is associated | |
with the report. And click manage | |
to update it. | |
Click on update data | |
and select update next to the | |
table you want to update. | |
And click submit. | |
You're returned to the report. | |
You will see that it is | |
regenerating and the updated | |
content shows the warnings that | |
Annie mentioned. Now I'm going to | |
hand it over to Aurora to | |
demonstrate some of the other | |
ways that JMP Live lets you | |
know you have warnings. Thank | |
you, Josh. OK, so Josh has taken | |
a post that was warnings-enabled | |
and now he's updated the data on | |
it so there actually are | |
warnings now, so I can show you | |
what that looks like from the | |
perspective of a regular JMP | |
Live user. We can see now that | |
his post looks a bit different | |
than it did before. It has a new | |
red icon on it that draws the | |
eye, and when we hover on that | |
icon it says there are control | |
chart warnings in this post. | |
What that's telling me in a | |
little bit more detail is, first | |
I know that the publisher of | |
this post cares about control | |
chart warnings because the | |
publisher has chosen to turn on | |
those tests within JMP desktop. | |
Second, I know the publisher | |
thinks that other JMP Live | |
users might care about control | |
chart warnings on this post | |
because that publisher has chosen to | |
enable that JMP Live feature. | |
And third, of course, I know that | |
there actually are control chart | |
warnings on the post. Now I'll | |
see this icon on any post. I | |
also see it on a folder if that | |
folder has a post inside of it | |
that fulfills all these same | |
criteria. If I click on this | |
icon, I am taken to | |
the warnings section of the post | |
details, just like I showed you | |
last time, only now there's more | |
interesting stuff in this | |
section. Now it tells me that | |
there are control chart warnings | |
and which columns those warnings | |
are present on (yield and brix | |
sugar) and it tells me some | |
details about the warnings. But | |
if I want more details, I can | |
scroll down just a bit and click | |
open log. That tells me a lot. | |
It tells me for every column | |
How many warnings there are; | |
what that translate to in terms | |
of warning rate; which tests | |
the publisher actually | |
decided to turn on an JMP | |
desktop; and also specifically | |
which data points failed | |
tests and which tests they | |
failed. I can also copy this | |
to my clipboard. | |
If I scroll down further to the | |
comments stream, I can see a new | |
system comment. It says the | |
posters regenerated because the | |
post content was updated, and | |
when the post content was | |
updated, there are now control | |
chart warnings on the following | |
columns. So you can see here | |
that these comments stream can | |
serve as kind of a high-level | |
history of what's been going on | |
with the post. Right now I'll | |
leave Josh a quick comment | |
saying it looks like reduced | |
irrigation had a | |
big impact. Now | |
the icon that I saw on the card, | |
that would be seen by any JMP | |
Live user, and any JMP Live user, | |
if they open the post details, | |
would see these system comments | |
and they would see this warning | |
section. But not just any JMP | |
Live user would get a new | |
notification actively pushed to | |
them, but I do have that | |
notification. I can see it up | |
here in my notifications tray. | |
And I also have one sitting in | |
my email inbox right now, and | |
it's very detailed. The email | |
contains all of the information | |
that is present when we saw open | |
log just a moment ago. Now, why | |
did I get this notification? I | |
got it because I'm a member of | |
the group that published...that | |
the post was published to. And | |
furthermore, the administrator | |
of that group has turned on this | |
JMP Live warnings feature. | |
They've enabled warnings for the | |
group itself, and by doing that, | |
the group admin was telling JMP | |
Live | I think the members of my |
group are really going to care | |
about control chart warnings, so | |
much so that you should actively | |
push notification out to them if | |
we get any new control chart | |
warnings on the posts in this | |
group. In other words, my | |
group admin agrees with the | |
publisher. They both want to | |
draw my attention to these | |
potential problems. | |
Now I'll turn it back to Annie | |
so she can walk us through the | |
next part of the grape trial. | |
Thanks, Aurora. | |
OK, so we we last looked at the | |
adding of the restricted | |
irrigation lot and now we have a | |
couple new lots come in. | |
Nothing, nothing special about | |
those. Let's take a look at the | |
graph. Um, what do we see here? | |
Well, we see the restricted | |
irrigation, but nothing special | |
with those. Let's see if | |
anything happened with the | |
sugar. No, we see the two new | |
points at the end after the | |
restricted irrigation, but | |
nothing special there and not a | |
whole lot new. But we do still | |
need to update the graph and | |
update it on the web. So Josh, do | |
you want to show us how we can | |
update it this time? | |
So I have already | |
demonstrated how you could | |
update the data through the | |
JMP Live UI, but you can | |
also do this through JSL. | |
First, I'm going to declare a | |
couple of variables, including | |
the report ID. The report ID can | |
just be found at the end of the | |
URL after the last slash; it's a | |
series of letters and numbers | |
that identifies the report to | |
replace. There are ways to | |
retrieve the report ID through | |
JSL, which I will show in a | |
moment, but for now we're just | |
going to save that. | |
We're also going to update our | |
updated data set that Annie just | |
showed you so that we can | |
provide it to JMP Live. So if I | |
run these, it opens the data table. | |
The next thing we need to | |
do is to create a | |
This will use this the | |
named connection that we... | |
that I created at the | |
beginning of the demo, | |
Discovery Demo server, here. | |
I use the new JMP Live command, | |
which will create a JMP Live | |
connection object. I provide | |
an existing connection and | |
it can prompt if needed, but | |
I've already authenticated. | |
So if I run this, | |
I get a new connection. As I had | |
mentioned at the beginning, you | |
can use this connection to | |
search for reports, as well as | |
get a particular report object | |
by ID. I'm going to use our | |
variable that I pasted in | |
to get the report we've | |
been working on. | |
That report can be... | |
you can get a scriptable | |
report from that result | |
object to get a live report | |
that you can examine for a | |
number of pieces of information. | |
Here I grabbed a live report | |
and got the ID. | |
I got the title, | |
description and the URL. | |
And you can see in the log that | |
the ID I retrieved | |
matches the one that I | |
pasted in | |
to the report. | |
I also got the title. | |
The description is blank 'cause | |
we didn't provide one when we | |
originally published. And I also | |
got the URL, the full URL, that I | |
could use to either open the | |
report through the script or for | |
some other purpose, such as | |
creating a larger report | |
that links to it. | |
In preparation of the next step, | |
I'm just going to get the | |
current date and time, which I'm | |
going to use to decorate the | |
title a bit, prove that we've | |
updated it through JSL. | |
But the key command here is | |
the update data command, which | |
lets us update just the data | |
of the report, just like I did | |
through the JMP Live UI. It | |
takes the ID as well, which | |
here I'm going to retrieve | |
from the live report object. | |
And then takes the data command | |
which you provide the new | |
data table that you are | |
uploading, as well as the name of | |
the the current data table that | |
you want to replace. | |
That | |
update result object can also | |
be queried to retrieve a | |
number of pieces of | |
information, like if it was | |
successful, the status you got | |
back, any error messages which | |
could be useful in a more | |
automated setting to provide | |
details as to why publish of | |
the new data failed. So I'm | |
going to run this. | |
And it said that it was | |
successful. And if I bring up | |
my report, you get this popup | |
that says an updated version | |
of this report is available. | |
Now I can choose to dismiss it | |
and continue looking at the | |
current context I have, but I'm | |
going to say to reload. | |
And we see the new data points | |
here without having to refresh | |
the entire page. | |
We go back to | |
JMP. | |
The last thing I wanna do is | |
show that other pieces of the | |
report can also be manipulated | |
through JSL. Here I'm simply | |
going to give it a new title. I | |
don't like the one that was | |
provided by default, so I had | |
declared this variable with | |
a new title, and I'm going | |
to append to that, the date | |
and time to help | |
distinguish when this | |
update was done. | |
I'm going to use the set Title | |
Command to send that to the live | |
report and then close my data | |
table to wrap up. | |
Run these and | |
bring up the report. In | |
a moment you'll see the | |
title refresh both here | |
and in the details. | |
Here it is with the date | |
and time. | |
Now I'm gonna hand it back over | |
to Aurora so she can show you | |
more of what happened in JMP | |
Live with this update. Thank | |
you, Josh. So I can see Josh has | |
updated title on his post. And so | |
he has updated a post that was | |
warnings-enabled and had | |
warnings. He's updated with new | |
data, and the new data, and just | |
like the previous data, has | |
control chart warnings. So I can | |
show you what this kind of | |
persistent warning situation | |
looks like to a regular JMP | |
Live user. So I can see here that | |
the icon that draws the eye and | |
says there are control chart warnings in the post | |
that's still present in a | |
persistent warning scenario. If | |
I open the post, | |
and I open the post details, I | |
can see the warning section. Only | |
now, it tells me I have warnings | |
on three columns | yield brix |
sugar and pH. If I scroll down | |
to the comments stream, I can | |
see that same notification about | |
the warnings here in the | |
comments stream. And I also, I'd | |
like to point out, have a new | |
active notification that is pushed | |
out to me. I have a new one here | |
and that's telling me that the | |
new data, just like the old | |
data, does have warnings | |
associated with it. Now I'll | |
turn it back to Annie and she | |
can take us through the next | |
Thanks, Aurora. | |
So last we talked, we were | |
looking at Lot #34. 33 and 34 | |
were added, so we've got | |
one new lot come in. That's lot | |
#35. Let's see how it looks. | |
Oh my goodness, the yield is way | |
out of...out of control. This is... | |
this is just unbelievable. This | |
is...this is just remarkable. How's | |
the sugar look? Well, the sugar | |
looks about normal, like we would | |
expect. The pH is also | |
about where we would expect. | |
This is something that's | |
clearly going to involve some | |
investigation, but we still need | |
to report this. Josh, would you | |
like to update the web? | |
So, | |
we've demonstrated that you | |
can update just the data of | |
the report, which is useful | |
when you want to keep the | |
report contents the same | |
and just update the data. | |
But there's also the ability to | |
replace the report which existed | |
before, and it's still useful if | |
you want to update the contents | |
of the report itself. | |
I realize in addition to | |
updating the data, I don't | |
really want to have this moving | |
range chart at the bottom. It | |
doesn't really make sense in | |
this context, so I'm going to | |
right click and say remove | |
dispersion chart and get rid of | |
that. So now the report is ready | |
to be replaced. | |
I got to file publish, publish | |
to JMP Live, and it looks like | |
it did before except instead of | |
selecting create a new post, I'm | |
going to decide to replace an | |
existing post and click next. | |
New in JMP 16, | |
we've updated this search | |
window. | |
My report is right at the top of | |
the list, but you also have the | |
ability to search by by keyword. | |
And... | |
and restrict the number of | |
reports if you've published a | |
lot, or this was a while ago and | |
you have difficulty finding it. | |
I'm going to pick the report I | |
want to replace and click next. | |
On this screen I get a | |
summary of the existing | |
picture and title. I'm going | |
to update the title, | |
just to draw attention to | |
the fact that I replaced it, | |
and give the description. | |
This time I know something might | |
be wrong with the yield. So | |
while the report does have | |
warnings, this time I'm going to | |
decide to uncheck the enable | |
warnings checkbox. Information | |
about the warnings will still be | |
sent to JMP Live | |
and be available at a later | |
time, but I don't want everyone | |
to get notified about the | |
warnings just yet. | |
Click publish. | |
And again, I'm told that my | |
report has been updated and I | |
can reload it. | |
And the new information for the | |
title and description appear in | |
the details. I'll hand it | |
back to Aurora so she can | |
show you what else has | |
happened in JMP Live. | |
Thank you, Josh. So just to | |
summarize, again, Josh has | |
taken a post that has control | |
chart warnings in it, but this | |
time when he republished it, | |
he decided not to enable the | |
I'm gonna show you what that | |
Live user because the content | |
publisher has control over | |
whether their control chart | |
warnings are exposed on JMP | |
Live in a way that's going to | |
draw the attention of other | |
users. And Josh decided that | |
that attention really wouldn't | |
be productive right now. So what | |
does it look like to me? It | |
really doesn't look like a whole | |
lot. There is no icon on the | |
card to draw my eye to it. I | |
don't have a new notification. | |
If I open the post and I open | |
post details, and I scroll down, | |
that warning section that I've | |
showed you several times before, | |
it's not even present, because Josh has | |
said I don't think other JMP Live | |
users really need to know | |
about the state of the warnings | |
on this post right now. | |
Furthermore, if I scroll down to | |
the comments stream, you know, I | |
can go back all the way to the | |
beginning and I can see when it | |
was published, it did not have | |
control chart warnings and then | |
it was updated and it did. It | |
was updated again and it still | |
did. The most recent comment | |
that I see says Josh Marquordt | |
has republished the post, and | |
it doesn't tell me anything | |
one way or the other about | |
control chart warnings. And | |
again, that's because the | |
whether these things are | |
exposed to other JMP Live | |
users. | |
While I'm here, I'll leave a | |
quick comment because I see in | |
the description that Josh wants | |
us to look at the yield. | |
And it looks very, very | |
off to me, so I'm going to say, | |
could this be | |
A data entry error? | |
Oops, that was my scroll mistake | |
and I'll submit that and then | |
I'll turn it back over to Annie | |
so that they can do some | |
troubleshooting on this process. | |
Thanks, Aurora. So we went back | |
and we talked with the data | |
entry people and it turns out | |
they were entering in pounds | |
instead of kilograms. As you | |
notice right here, we're in | |
kilograms. So we updated the | |
data, did a little division | |
on it, and now the yield | |
looks like more like what we | |
would expect. The sugar and | |
the pH have been unaffected. | |
Josh, would you like to | |
show how to republish? | |
Yes, so we've shown several ways | |
to update the data. I'm going to | |
go back to the first way I | |
replaced it by updating it to | |
the the JMP Live UI. I'll click | |
on details. And scroll down | |
to the data section | |
again, click manage. | |
Update data. | |
And when I click update I'm | |
going to select the fixed | |
data that Annie just | |
presented and submit. | |
Go back to the report, see | |
it regenerate. | |
And | |
like we noted the | |
yield is back to looking | |
normal. I'm going to leave | |
a comment for Aurora to let | |
her know that we fixed the | |
...the units. | |
Then hand it back to her to show | |
you what has changed in JMP | |
Live. Aurora... Thank you, Josh. | |
So I can see his post here. I | |
can open it and right away | |
looking at the report itself I | |
can see that things look a lot | |
better on the yield. So I'm | |
curious about what that what | |
that was. I'm going to scroll | |
down here and actually I can get | |
here because I notice I have a | |
new notification. What's that | |
about? I click on it and I see | |
that Josh has replied to my | |
comment; that will take me | |
directly to the post also. And | |
if I scroll down to those | |
comments and I look at that | |
reply, I can see, OK the units | |
were in pounds instead of | |
kilograms. It's been fixed now. | |
Fantastic. So it looks like the | |
grape trial is back on track | |
and we're making good progress. | |
Um, I'd like to take a step back | |
now and talk about the different | |
kinds of JMP Live users that | |
there are and how they interact | |
with control chart warnings. | |
We've talked a lot during these | |
demonstrations about the power | |
that Josh had as the content | |
publisher. The content publisher | |
has control over which tests are | |
turned on or not in JMP | |
desktop. And the publisher | |
also has control over whether | |
or not to enable this JMP | |
Live feature on the post. | |
But before when I got a | |
notification about control chart | |
warnings, I mentioned that I got | |
it because the post is published | |
to a particular group. So I'd | |
like to show you a little bit | |
more about those groups. If I go | |
to the groups page, I can see | |
the Wine Trials Group that this | |
post has been published to, and | |
I can see that it is warnings- | |
enabled. If I hover over that, it | |
says control chart warning | |
notifications will be sent to | |
members of this group. Let's | |
open that group up. | |
You can see here as well that | |
it's enabled and because I | |
actually happen to be the | |
administrator of this group, I | |
can change that. If you come over | |
here to the overflow menu, | |
which is these three dots, | |
click that, and I have the | |
option to disable warnings and | |
stop sending these | |
notifications out to my group | |
members. | |
I can also change it bac. If I | |
change it from disabled to | |
enabled, then I get a prompt and | |
it says send notifications now. | |
JMP Live is telling me, | |
OK, you've got a group; | |
it's got some posts in it; | |
because you didn't care | |
previously about control chart | |
warnings in this post there | |
could be posts in this group | |
already that have warnings and | |
none of your members know | |
about it. So now that you do | |
care about control chart | |
warnings in this group, would | |
you like me to go ahead and | |
send out notifications to all | |
of the members of the group | |
about any control warnings | |
that already exist on the | |
posts in here? I'll say no for | |
now because we already know | |
about this particular problem. | |
But what if I'm not a content | |
publisher and I'm not a group | |
administrator? I'm just a | |
regular JMP Live user and I'm | |
getting notifications about | |
other people's processes. As with | |
any other kind of notification, | |
I can opt out. And I would do | |
that by going up here and | |
clicking on my notification bell | |
icon, clicking on the settings | |
icon. And if I scroll down, I'll | |
see that there is a new type of | |
notification called control | |
chart warnings. I can toggle | |
this on or off to say whether or | |
not I want these notifications | |
at all. And if I do, | |
I can let JMP Live know with | |
what frequency I want to receive | |
emails about these | |
notifications. I think that | |
Josh also has some closing | |
thoughts for us, so I'll | |
turn it over to him, Josh. | |
Thanks, Aurora. | |
So we demonstrated the new control | |
chart warnings in JMP Live 16, | |
how it lets you notify | |
interested parties about tests | |
that generate warnings in | |
We've shown some new features in | |
the JMP Live UI that draw | |
attention to the warnings and | |
give you details about what | |
occurred. And settings to control | |
the notifications and warnings | |
from the perspective of both the | |
publisher and group admins. | |
We've also shown that there's | |
several ways to update | |
reports and get data into | |
JMP Live 16. You can publish | |
a report from the JMP | |
desktop. | |
You can update just the data, | |
which is a new feature in JMP | |
Live 16, through both the JMP | |
Live UI, as well as updating just | |
the data through JSL. | |
And you can also still | |
republish a report | |
from the JMP desktop | |
to change its contents. | |
I only briefly touched on the | |
JSL capabilities in JMP Live | |
16 so if you're interested in | |
more details or on how to take | |
this process and automate it, | |
please see Brian Corcoran's | |
talk on the JMP community at | |
The Morning Update | Creating |
An Automated Daily Report to | |
Viewers Using Internet-Based | |
Data. It takes a control chart | |
warnings example and shows how | |
you might make this a daily | |
process that publishes | |
automatically. | |
Please see our talk on the JMP | |
community and leave us feedback. | |
Finally, we wanted to say thank | |
you. We are just a few members | |
of a much larger...several teams | |
that have worked on this | |
feature. On the JMP | |
desktop in Statistics, Annie | |
Dudley Zangi and Tonya Mauldin | |
worked on Control Chart Builder. | |
The JMP Live team led by Eric | |
Hill contributed to both this | |
feature and many of the other | |
features that we got to | |
indirectly show while giving | |
this demo. The JMP | |
Interactive HTML team led by | |
John Powell created the content | |
of the reports of control chart | |
folder in JMP Live. | |
Our UX and design work is done | |
by Stephanie Mencia and our project | |
manager is Daniel Valente. | |
Thank you. | |
Thank you everyone. Thank you. |
