Testing the Usability of a New User Interface in JMP Custom Design - (2023-US-PO-1428)
Several authors have addressed validating statistical software. More work is needed to assess the usability of such software since modern statistical software is increasingly in the hands of users with limited statistical training to address complex real-world problems. This poster presents a usability case study for a design of experiments tool in JMP.
The study focuses on a dialog used to specify a designed experiment. Such specifications require users to identify factors, responses, the linear regression model, and constraints. The cost of conducting experiments is usually a primary concern, so users typically iteratively refine specifications before experimenting. As a result, the ability to easily specify and change specifications is essential to users.
We begin with the challenges of the current dialog related to discoverability, clarity, and tedium when performing everyday tasks. We present details of the usability study, including dialog prototypes that address various challenges. We discuss how these prototypes were dynamically generated with the JMP Scripting Language and how the usability of each prototype was assessed by using simple and complex tasks. We discuss the variables and regression model used to assess the potential effect of each variable or combinations of variables. We also explain how we used JMP Custom Design to determine the best configurations for each subject, with the order of the configurations accounting for the subject’s learning over the study, as well as how qualitative data were collected by using an integrated questionnaire that was presented after all tasks were completed.
Hello.  I'm  Mark  Bailey.
I'm  here  with  my  colleague  Jacob  Rhyne,
to  talk  about  some  recent  work  on  the  new user  interface  in  JMP  Custom  Design.
The  primary  focus  of  our  work
was  a  usability  study to  evaluate  the  new  interface.
First,  I'm  going  to  talk   a  little  bit  about  the  current  interface
and  our  motivation  for  the  change.
We  think  of  experimentation  as  a  workflow.
In  the  very  first  step,  we  define our  factors,  responses,  and  goals.
This  critical  step  determines so  much  in  what  follows.
Adding  factors  is  a  very  important  step when  you're  designing  an  experiment.
We  learned  that  customers have  some  difficulty
with  common  tasks  around  defining  factors.
There's  confusion  about  adding, deleting  or  renaming  factors.
They  find  it  difficult  to  change the  factor  type,  the  factor  levels,
even  reordering  the  factors  in  the  list.
Figure  2  shows  the  original User  Interface  for  comparison.
The  goals  for  this  prototype were  to  decrease  confusion,
to  reduce  the  number  of  operations  in  the time  that  it  took  to  achieve  the  result.
Our  usability  study  wanted to  compare  different  controls
that  might  be  used to  achieve  these  goals.
Figure  3  shows  the  prototype for  the  new  user  interface.
This  prototype is dynamically  configurable.
That  is,  we  can,  that  will  turn different  user  controls  on  and  off.
This  led  to  a  prototype with  384  possible  configurations.
It  was  impossible  to  include  all of  them  in  a  usability  study.
A practical  study  required a  smaller,  optimal  design.
Looking  at  figure  3, especially  along  the  top,
you  see  the  User  Controls
that  we're  going to  primarily  focus  on in  our  usability  study.
You  see  the  Trash  icon, the   Delete icon,
the  Plus  and  Minus  buttons, the  Undo  and  Redo  buttons,
the  Add  N  Factors  control, and  what  we  call  our  Buffet  menu  button.
In  figure  4,  you  see  just  two of  the  384  possible  configurations.
In  order  to  make  sure that  the  usability  study
was  efficient  and  effective, we  used  Custom  Design
to  make  most  of  the  runs  for  our  study.
In  this  case,
some  of  the  User  Interface  controls were  treated  as  a  binary  factor.
That  is  they were  turned  on  or  off  in  the  prototype.
Other  User  Interface  controls could  have  more  than  just  two  states.
Each  time  the  subject  was  asked to  perform  several  different  tasks
repeatedly  with  different  configurations for  comparison.
In  the  table  in  the  lower  left,
you  see  all  of  the  factors that  were  included  in  our  study.
The  first  six,  seven, have  to  do  with  controls
in  the  User i nterface  that  were  turned  on or  off  or  to  a  different  state.
The  last  factor  is  the one  that  determined
what  we  wanted  them  to  do with  a  particular  configuration.
That  is  we  asked  them to  delete  a  factor,
change  the  type  of  the  factor, or  change  its  position  in  the  list.
On  the  right  in  figure  5,
you  see  the  completed Custom  Design  platform
with  the  response  defined.
We're  going  to  measure  the  time  it  takes for  them  to  complete  each  task.
We're  trying  to  minimize  that.
All  of  the  factor  definitions, and  finally,  the  model
that  we  want to  use  to  quantitate  the  time to  complete  each  task.
I'm  now  going to  turn  it  over  to  Jacob.
Who's  going to  talk  about the  resulting  Custom  Design,
how  that  fit  into  our  study, and  our  findings.
Thank  you,  Mark.
Mark  has  laid  out  how  we  use the  Custom D esign  platform  in  JMP
to  set  up  our  usability  study.
In  figure  6,  you  can  see,  all  the  runs in  the  study,  for  the  first  participant.
I'll  note  that  we  did  include a  participant  and  Run  Order  in  our  design
as  covariates  because  we  wanted  to  include these  in  our  analysis  as  well.
You'll  also  note  from  figure  6   that  we  included  a  few,
what  we  call, special  tasks  in  our  study.
These  were  tests  we  knew  would  take longer  to  complete,
and  we  didn't  want to  ask  participants to  do  these  more  once.
If  you  look  at  the  final  task   of  the  of  the  study,
these  were,  special  exercises   that  we  ask  the  participants  to  complete
a  series  of  tasks  using  a  provision of  the  prototype
and  the  same  series  of  tasks  using the  Custom  Design  platform.
This  allows  us  to  get  a  direct  comparison
between  the  new  configurable  prototype   and  Custom  Design.
To  apply  this  Custom  Design, we  developed  a  custom  JSL  application
that  allowed  us  conduct an  unmoderated  usability  test.
Now  I'll  give  an  example of  how  this  works  in  figure  7.
From  the  top  of  figure  7,
you  can  see  that,  for  Run  Order  2, the  task  was  to  delete.
As  you  can  see  in  the  second  part of  the  screenshot,
the  instructions  the  participant  saw in  the  study,  instructed  them  to  click
the  Launch  Prototype  button and  then  delete  the  factor  charge.
When  the  participant  clicked the  Launch P rototype  button,
the  version  of  the  prototype  that  appeared here  in  the  third  part  of  the  screenshot,
that's  entirely  determined by  the  other  factors  in  our  study.
For  example,  you  could  see the  Trash  icon  is  set  to  off.
That  means  you  don't  see   the  Trash  can  icon,
down  here  in  the  prototype.
The   Delete icon  is  on, so  you  do  see  the   Delete icon.
For  every  exercise,  in  our  study,
the  version  of  the  prototype that  appears  and  the  instructions
that  the  participant  would  see
is  entirely  determined   by  our  Custom  Design.
Let's  look  at  some of  the  qualitative  results  from  our  study.
In  our  usability,  study  scripted we  included  an  integrated  questionnaire
at  the  end  where  we  ask  participants to  get  us  some  feedback
on  what  they  liked, what  they  didn't  like,  et cetera.
I'll  highlight, a  few  of  the  options  in  figure 8  here.
We  ask  participants  to  give  us  feedback on   whether  they  liked  using
the  Plus  button or  the  Add N  Factors  control
to  add  factors,  and  you  can  see from  the  top  of  figure  8
that  participants  overwhelmingly preferred  using  the  Plus  button
to  the  Add N  factors  control.
We  also  ask  participants  how  they  liked, Deleting  factors,
either  using  the   Delete icon   or  the  Trash  icon.
In  this  case,  the   Delete icon was  overwhelmingly  preferred.
We  also  asked  participants, what  was  their  favorite  Row  icon
that  you  could  see  beside  the  rows in  the  factor  list.
The  Pin  icon  was  the  most  popular  with, giving  five  of  the  10  votes,
compared  to  the  Oval  icon, which  only  got  two  of  the  10  votes.
Then,  finally,  I  point  out  if  you  look down  towards  the  bottom  of  figure 8,
you  can  see  that  the  participants overwhelmingly  voted
that  the  User I nterface of  the  new  prototype  was  easy  to  learn.
It  was  the  new  interface was  also  greatly  preferred,
to  the  original  factor  listing Custom  Design.
Now  let's  look  at  some  of   the  quantitative  results  from  our  study.
We  got  these  results  by  using the  generalized  regression  platform
available  in  JMP  to  fit  models
for  the  time  it  takes  to  complete the  task,  and  the  factors  in  our  model
or the  effects  on  model,  excuse  me,
or the  different  elements of  the  prototype.
If  you'll  look  at  figure  9,  for  the  output of  our  generalized  regression,
you  can  see,  that  the  factors, Row  States,  Trash  icon,
and  Pin C olumn  Type  were  found  to  have a  significant  impact  on  time.
You  can  also  see, from  the  profile  or  the  Run  Order,
in  this  case,  did  not  have a  significant  impact  on  time.
Let  me  draw  your  attention, to  the Pi n  Column  Type F actor.
You  can  see  that  the  time  to  complete, the  task  of  changing  a  factor  order
was minimized  when  the  Oval  icon was  used  to  complete  the  task.
I'm  pointing  out this  Pin  Column  Type  Factor  specifically
because  in  this  study, the  way  participants  would  change
the  order  of  a  factor  is  they  would  click the  Row  icon  beside  the  factor
in  the  factory  list  and  drag that  icon  to  the  appropriate  spot.
In  this  case,  the  Pin  Column T ype is  what  I  wanted  to  focus  on.
Looking  at  figure  10, you  can  see  that,
participants,  when  they  were  asked  to  tell us  their  favorite,
only  two  of  the  10  participants reported  liking  the  Oval  icon.
When  it  came  to  completing  the  task, that  participants  interacted
with  the  icons  the  most,  the  Oval  icon was  actually  the  best- performing  icon.
Now  let's  look  at  the  results, for  the  task  of  deleting  a  factor.
In  this  case,  participants  would  be  asked to,  given  version  of  the  prototype,
remove  one  factor  from  the  factor  list, and  they  could  do  that  by  either  using
the   Delete icon,  the  Trash  icon, or they  could  have  the  option  to  use  both.
Again,  we  fit  models  using a  generalized  regression
with  time  as  the  response, and  you  can  see  that,
the  icon  was  used  and  Run  OrderThe bot had  a  significant  impact  on  time.
The  time,  for  this  task  was  minimized when  the   Delete icon  was  used  as  opposed
to  using  the  Trash  icon or have any  option  to  use  both.
In  contrast,  to  the  previous  slide,
our  quantitative  results  here  match the  qualitative  results
because  as  you  can  see  in  figure  12,
the  participants  overwhelmingly  preferred the   Delete icon,  to  the  Trash  can  icon.
I'll  end  this  study  by  commenting on the  results  of  the  last  two  exercises.
The  last  2  exercises  in  the  study,
we  had  we  had  participants  complete a  series  of  exercises  using  the  prototype
and  then  complete  the  same  series of  exercises  using  Custom Design.
The  instructions  for  the  exercises were  the  same.
The  only  thing  that  was  different  is in  one  case  you  use  the  prototype,
and  in  the  next  case, you  use  Custom  Design.
When  participants   were  giving  the  prototype,
it  took  them  an  average of  68  seconds  to  complete  the  task.
When  participants   use  Custom  Design  platform,
it  took  them  an  average  of  316  seconds   to  complete  this  exercise.
I'll  also  note  this  316  seconds is right- centered
because  a  couple of  the  early  participants
that  we  gave  the  study  to reported  that  they  gave  up.
A fter  this,  we  started  popping  up a  notification  after  five  minutes  saying,
"We  thank  you for   completing  this  exercise.
You  can  move  on  to  the  next  one."
That's  all  we  have  to  share  today.
Want to  thank  you  for  your  interest in  our  poster,
and  please  let  us  know if  you  have  any  questions.
