Traditionally, control charts for attribute data (p-charts and u-charts) assume the data is either binomial or Poisson, and that the mean is constant over time. However, this assumption is rarely true in practice. David Laney developed a technique that solves the problem so that control charts work well, whether the mean parameter is stable or not. This talk explains the evolution of the Laney P' and U' charts and gives examples of how best to apply them.
Hi , I 'm Annie Dudley ,
and I am a Control Chart Developer for JMP .
I am here today to talk with you about the new in JMP version 17
Laney P ' and U ' control charts .
Let 's review.
The control charts are intended to show the stability of your process .
If your process is not stable , then you can 't reliably make the same size
or the same parts , and customers will get upset
and not want to purchase from you again .
In this case , we 're talking specifically about attribute charts ,
which are based either on the Binomial or the Poisson distribution ,
and they assume a constant variance,
a constant variance because both the Binomial and the Poisson
are a one parameter distribution .
You got one parameter for the mean and then manipulations on that
for the variance .
But what happens if your variance is not constant over time ?
When you have a non -constant variance ,
in other words ,
if you have more variance in your model or in some cases , less ,
more variance in your model than you 're currently describing ,
that 's referred to as overdispersion .
One parameter model cannot model overdispersion .
David Laney proposed that we normalize the data
and we account for varying subgroup sizes , we compute a moving range ,
and average that , and then we insert that into our model ,
into our limits for the control charts .
Let 's take a look at this in JMP .
Let 's keep in mind this assumption is that for the regular P and U charts ,
we have this assumption of the probability of nonconformity
is the same for each sample .
In other words , we have assumption that our variance is constant .
Let 's look briefly at our limits formulas .
For the P chart , it 's the average plus or minus 3
times our standard error and the same with the U chart .
Again , remember , we have this one parameter .
There 's not much that we can do if our limits are not constant here
or if our variance is not constant .
What do we do if we have overdispersion ?
This is the big question .
What Laney proposed was basically we standardize our data ,
we take the moving range , we compute an average moving range ,
and then we adjust that and form a sigma sub Z .
These limits that Laney is proposing look very similar to the other limits .
We were just inserting the sigma sub Z into the formula
right before the standard error for both the P charts and the U charts .
Let 's take a look at an example .
I 'm going to start with a data set from the JMP sample data folder .
We have lot sizes that are not terribly large .
F or our first example , let 's look at this one .
I 'm going to go through the interface for this first one .
We 'll use dialogs for future ones .
We have the number of defective washers that we 're going to model .
I 'm going to change the chart type to attribute .
Before we go to Poisson , I have my lot as my i dentifier for our X -axis ,
and we 're just going to use the constant lot size of 400 .
Drop that in the n Trials drop zone .
Now , Laney 's charts are only available when our statistic is proportioned ,
so I have to change that back to proportion .
When the statistic is proportion , then we have four choices
for our sigma value .
I 'm going to choose Laney P '. But first , let 's take a look here .
We see we have two points out of control on this P chart,
which is indicating to us that this is not a stable process .
We can certainly turn on the limits , and that just affirms what we spotted .
If we change the Laney P ' chart , that sigma sub Z
was clearly greater than 1 , because now our limits
have jumped up considerably .
While the points being plotted are the same as they were on the P chart ,
the upper limit in particular
has gotten larger .
There 's a fairly simple example .
Let 's move on to another example .
This is again , another data set out of this JMP sample data .
In this case , we 're looking at the number of defects out of ...
We have several units that are being tested ,
several braces that are being tested in each unit .
Each unit isn 't the same size .
This is another scenario where
this problem with the non -constant variance pops up.
We can count the number of defects .
We 're not counting the number of defectives.
We 're counting the number of defects per unit .
In this case , our unit size is varying .
Let 's choose a U chart under the Control Chart menu.
We have our number of defects , and we have our date
as our subgroup identifier , and we have our unit size
as our n Trials .
We talked about having that non -constant unit size ,
so we have varying limits.
We do see some of the points are out of control here .
Again , this appears to be a non -stable process,
which is cause for panic or having to readjust everything .
Now , if we show the control panel , since we have proportion as a statistic ,
we can change this from a Poisson or CNU to a Laney .
Again , the limits have now increased .
We now realize we have a stable process . We don 't have any points out of control .
This is better characterizing our scenario , our data here .
Now , let me show you a third example , which is a little bit more complex .
The picture in my background here is actually a picture I took
from Acadia National Park .
A couple of summers ago , I was working at the Schoodic Point
and volunteering to study microplastics in the water up there .
We were taking samples of one liter of water per week at different locations .
We would take that water , and we would pour it through a filter ,
and then we take the filter and look under a microscope
and physically count the number of micro beads and microfibers
that were appearing on the filter that we poured the water through .
Let 's analyze this as a control chart .
The principal investigator for this particular study
is trying to form a nice , complex model over time
to find out whether or not the water plastics were increasing .
But in order to do that , you really want to know
that you 're modeling your data correctly
and whether or not we have actual stable data .
This is an example where we could run a P chart ,
so let 's try that .
Being the control chart developer , I 'm always looking for more opportunities
to model control charts .
We want to look at the total plastics.
For our subgroup , we have week ,
and for our n Trials , we have total volume ,
and then we have different site IDs as a phase .
Here we see we have three different points that we were taking the measurements from .
Some were better than others ,
but they all seemed to be really out of control .
He 's going back to the drawing board and like , "What should I do ?
Should I take more data ? How do I ..."
I thought , "Hmm , let 's see if this really is characterizing the situation ,
the process here very well. "
Let 's run this again through a dialog ,
and you see there are two new entries on the menu ,
one for Laney P ' and one for Laney U control chart .
Again , let 's look at our total plastic as the Y ,
and the total volume is our n Trials .
Our week is our subgroup , and the site ID is the phase .
We 've got the same points again , but suddenly, our limits are much wider .
We can conclude from this that , well , we actually have a pretty stable process .
This is good data .
He can go ahead and start to form his larger model on this data .
While it 's a calming thing , also, it makes a lot more sense .
In closing , I would like to recommend that everyone use the Laney P ' and U '
control charts when monitoring your proportion
of non -conforming or defects ,
especially when you see a difference between the P and the P ' chart .
Thank you very much .
0 Comments
Published on ‎03-25-2024 04:55 PM by Staff | Updated on ‎07-07-2025 12:10 PM
Let 's review.
for the variance .
in other words ,
has gotten larger .
as our n Trials .
This is good data .
