Behind the Scenes: Software Development in JMP® Live (2021-EU-PO-732)
Aurora Tiffany-Davis, JMP Senior Software Developer, SAS
Get a peek behind the scenes to see how we develop JMP Live software. Developing software is a lot more than just sitting down at a keyboard and writing code. See what tools and processes we use before, during and after the "write code" part of our job.
Find out how we:
- Understand what is wanted.
- Define what success looks like.
- Write the code.
- Find problems (so that our customers don't have to).
- Maintain the software.
Auto-generated transcript...
Transcript |
Hi I'm Aurora Tiffany-Davis, a software developer on the |
JMP Live team and I'd like to talk to you today about |
how we develop software in the JMP Live team. |
First, I'd like you to imagine what software development looks |
like to you. If you're not a developer yourself and the |
picture you have in your mind is probably colored by TV and |
movies that you've seen. |
You might be picturing an oddball genius who works alone, |
and the process for developing software is very simple. They |
think really hard about a problem. They write some code |
and then they make sure that it works. And it probably does, |
because, after all, they are a |
genius. If we were all geniuses like Hollywood says that we are, |
this process might work for us, but actually we're only human, |
and so we need a bit more than |
that. First of all, we don't work alone. We work very |
collaboratively and we have a process that helps us to |
produce quality software. I'll point out here that there is no |
one correct process for developing software. Your |
process is going to differ across companies and often even |
within companies. But what I'll do today is walk you through |
what I would do if I were developing a new feature in |
JMP Live. |
First of all, before I ever sit down to write code, I have to |
have some actual need to do so. There has to be some real person |
out there who has found something in JMP Live that |
doesn't quite work the way that they think it ought to, which is |
a nice way of saying that they found a bug or they have a |
request for a new feature. We keep track of these issues in an |
internal system, and so the first thing I would do is go to |
that system and find a high-priority issue that's a good |
match for my skill set, and start thinking about it, and start |
talking about it. The next thing I would do is try to understand |
the need by talking to people. What kinds of users are going to |
need this feature? How are they |
going to use it? Then I would run JMP Live on my own machine, |
and start to take a look at where the new feature might fit |
into JMP Live as it already |
exists today. Then I would bring up the code and start thinking |
through how the new code is going to fit into our code base. |
Once I think I have a good understanding of the need, I |
would move on to the design step. And here again, my first |
step is going to be to talk to people. I'll talk to user |
experience experts that we have within JMP and I'll talk to my |
coworkers and ask, "Have you worked on a feature similar to |
this before? Have you worked in this part of the code before?" |
Then I'll start to flesh out the design. I might write articles |
and draw diagrams and share these around so that I can make |
sure that the other members of the team are generally |
comfortable with the direction |
I'm moving in. Now I'll sit down and start to write some |
code. And for this I'll use the integrated development |
environment, which is a program that has a lot of |
features designed to help us do better at our job. |
Now that I've written some code, my first step is to find the |
problems that I just created. I'm only human, so the chances |
that I wrote 100% flawless code on my first try are pretty slim. |
My first step is going to be to |
use static analysis. Static analysis doesn't run the code, |
it looks at it as though it's written down on a piece of |
paper. An analogy might be spellcheck in Microsoft Word. Spellcheck |
can't tell me whether or not I've written a compelling |
novel, but it can tell me if I missed a comma somewhere. |
Static analysis does that for code. |
Now that I have found and fixed those very obvious problems, my |
next step is going to be to look for less obvious problems, |
and for that I'll use an automated test suite. We have |
written a broad range of tests against our code. Automated |
tests do run the code, or rather it runs a subset of the |
code, provided a certain input, and expecting a certain output. |
It's a really valuable exercise to sit down and write these |
tests, because sometimes when I sit down to write a new test for |
any feature, it forces me to really clarify my thinking about |
how the software is supposed to work in the first place. |
It also provides a really crucial safeguard against |
colleagues accidentally breaking this feature in the future. So |
it's a great way to find |
problems early. Once I've written and run these automated |
tests, I'll move on to some manual tests. I might run JMP |
Live on my local machine, or on one of several servers we have |
in the office and poke around and try stuff and just make sure |
that it works the way that I |
think it ought to. I may even look into the database that |
sits behind JMP Live and keeps track of records on |
users, posts, groups, comments, and make sure that records are |
written in the way that I expect them to be. |
Now I'm cautiously optimistic that I've written some good |
code, and I've created a useful |
feature. The next step is to ask my peers for their opinion. I'll |
put this through peer review. Now in JMP Live, we put 100% of |
the code that we write through peer review and the reason is |
that we find it so valuable. |
There might be something I have missed because I just sort of |
have blinders on about something. Or it might be the |
case that somebody else on my team simply has knowledge that I |
lack. It's often the case in a review that the reviewer also |
gets a lot of value out of the exercise because they might |
learn about some new techniques. |
Now that the team is pretty optimistic that we've created |
some good code, I will finally commit my code or check it into |
a source code repository. |
We have a continuous build system that watches for us to |
commit code, and when we do, it |
analyzes it. It looks for really basic stuff like, are the files |
named the right way and in the right place? It will also rerun |
static analysis and it will rerun our entire automated test |
suite. It does this in case someone has forgotten to do this |
earlier in the process. Or more often, it could be the case that |
something small and subtle has changed since the last time the |
automated test suite was run. |
So it does all these analyses and when it makes it through |
this step, the code is now available for people outside of |
the development team to take a |
look at it. The first people who pick up on this are the testing |
experts that we have within JMP Live and within the JMP team |
more broadly. These are test professionals. It's what they do |
for their whole career, and they're really good at it. |
They might rerun automated test suite. They might add more tests |
to our suites. They might run JMP Live manually and poke around |
generally. They might run JMP Live locally and pretend to do |
things as users that would be absolutely insane. What's the |
craziest thing the user can do? And let's see how the software |
responds to it. They're really creative with these test |
scenarios. They might also run the software on various |
different browsers and operating systems to make sure that our |
software is flexible and robust. |
Once they have signed off on this new feature, it's now |
available to be picked up in our next software release. |
Let me zoom out now and show you the process as a whole. |
That's a lot of steps. Do we actually do all of this for all |
of our software changes? Believe it or not, we do. However, this |
process scales a great deal, depending on the complexity of |
the work. If we have a really simple obvious bug, we'll step |
through this process, but we'll do it pretty darn quickly. |
On the other hand, if we have a very complex new feature, at |
every step of the process, we're going to slow down. |
We'll take our time and take a lot of care to make sure that |
we get it right. |
Now, anything that takes time costs money, so why is it that |
JMP is willing to invest this money in software quality? |
One reason is really simple. We have pride in our work and we |
want to produce a good product. |
The next reason is rather less idealistic. We know that |
whatever problems exist in our |
process, and in our product, if we don't find them, our |
customers will and that's not great for business. So we |
would like to minimize that. |
Now no process can deliver |
absolute perfection. And so we really invite you to stay a part |
of the JMP community. Go to community.jump.com and let us |
know if there's anything about JMP Live if it doesn't work the |
way you think it ought to, or anything new that you would like |
to see in the future. |
That kind of real-world feedback is immensely valuable to us, and |
we really welcome it. |
That's all I have for you today, but I really hope that |
you enjoy the rest of your Discovery experience. Thank |
you. |
