Is Belgium chocolate really better than US chocolcate?
A blind taste test with 25 subjects testing 5 pairs of chocolates. The experiment was designed using the JMP Custom Designer, and the data are analyzed using JMP's Choice platform. See the JMP blog for a description of the experimental design and the resulting analysis.
