Univariate Binning using the Normal Mixtures Distribution
MathStatChem
Level VI
This is a "re-upload" of an add-in I had placed on the previous JMP File Exchange.
I allows you to create a binned version of a variable based on clustering rows, using the Univariate Normal Mixtures Distribution.  Note that this treats columns one-at-a-time, and doesn't use multivariate clustering to assign the rows to bins.
See the blog post "Is your data too precise?" for where this was originally presented and used.
Comments
Minwoo_Son
Hi, does this add-in support JMP 15?(not pro)
I downloaded and installed, it seems like this is not working.
Hello SAS/JMP/Community, it would be nice if we could fix this add-in for JMP 15. It is a great add-in idea and will be tremendously useful. However it did not work on my JMP 15 as well.
