Submit your abstract to the call for content for Discovery Summit Americas by April 23. Selected abstracts will be presented at Discovery Summit, Oct. 21- 24.
Discovery is online this week, April 16 and 18. Join us for these exciting interactive sessions.
Data Table Support for Images in JMP 12 (Supporting Files)
After unzipping the files, open the data table and run the script. A summary table will be created, with an expression column that houses a different graph in each row. Since the graph column has the label property turned on, hovering on a given row's point in a graph will display the row's image.
NOTE: Requires JMP 12.
