This add-in contains tools for the analysis of data from Electrochemical Impedance Spectroscopy (EIS). It wraps functionality from the Python Package Impedance.py. After installing the add...
Jordan_HillerPurpose The Torch Deep Learning Add-In for JMP® Pro provides a no-code interface to the popular Torch library for predictive modeling with deep neural networks. T...
SamGardnerThe Documentation add-in installs the individual PDF files for all JMP books, and the Documentation Library, which is a concatenation of all the books into one PDF. The add-in also installs a new men...
Qiana_EaglinThe Documentation add-in installs the individual PDF files for all JMP books, and the Documentation Library, which is a concatenation of all the books into one PDF. The add-in also installs a new men...
Qiana_EaglinPurpose Here is an attempt of my first application built with app-builder using the connection between JMP and Python to handle a complex machine learning algorithm. The purpose of this app is to...
Franck_RThis JMP Add-in is to transform non-normal quantitative trait data typically analyzed in Genome Wide Association Studies (GWAS). The method implemented is rank-based inverse normal transformatio...
Chris_KirchbergThis add-in imports interactively Apache Parquet files (https://parquet.apache.org/) into JMP tables. It consists of two commands: Single file: select a single .parquet file, checks its validit...
MassimoMartucciNote: This was previously called Column Filter (jthi.column.filter). Uninstall that version before installing this. This add-in lets you easily change multiple columns in your Graph Builde...
jthiUpdates November 27, 2023 - Version 1.1 - improvements and bug fixes, details are in a post below November 28, 2023 - Version 1.11 - minor bug fix December 15, 2023 - Version 1.2 - im...
scott_allenDescription Have you ever needed to share data and collaborate with a colleague who is not a JMP user? Perhaps you export data to Excel for those colleagues, only to lose the JMP for...
Justin_Chilton(18Aug2019) - A note from the author Hi, All! It's time to start thinking about a new version of the STK... I've got some things that I'd like to do, but I also want to hear from those using ...
MikeD_AndersonThe Imbalanced Classification add-in features sampling techniques that attempt to impose a more balanced distribution between the two classes. The sampling techniques include the synthetic minority o...
michael_jmpThis is an Add-In to facilitate a decision-making process where multiple criteria are considered. The method uses layered Pareto Fronts to reduce the number of choices from which to choose and also a...
seburke89This add-in ingests estimates from an ordinary least squares report (produced by Fit Model) and saves a table of model effect estimates, F-ratios, p-values, and three measures of effect size as formu...
julianThis addin contains several utilities for working more efficiently with data tables. With it, you can: Quickly set the number of decimal places displayed in the data table. Set and cha...
brady_bradyこのアドインについて このアドインは、JMPのガウス過程モデルを利用して、ベイズ最適化を行うためのアドインです。 システム要件 JMP 15以降 表示言語は、英語および日本語のみ ベイズ最適化について ベイズ最適化は、逐次的な実験を繰り返し行い、最適解を探すときに使用される手法の一つです。ベイズ最適化の主な流れは、次の通りです。...
yuichi_katsumurThis is designed to help new users become comfortable with running different analyses in JMP. The add-in will ask the user to pick an analysis task, analysis goal, and data type. ...
Peter_HershThis add-in provides a library of common conversion functions for length, area, volume, mass, energy and temperature, time, speed and pressure, as well as some miscellaneous conversions, inc...
ChrisCostin
