Create formula columns to code for missing values
Informative Missing is a great feature in Fit Model in JMPPro, but to do the same without JMP Pro you need to make some formula columns. This add-in makes it easier to do. The idea is to be able to fit using columns that have missing values, and rather than imputing the missing value, you can using a coding system to make it predictive as missing.
