Demonstrate Regression
    Explore regression concepts, including: Intercept, slope, correlation, least squares and sum of squares, residuals, R Square, parameter estimates, test statistics and p-values. Manipulate population characteristics, sample size and plotted data to explore the influence on the regression equation and results. (Author: Mark Bailey, SAS Institute.)
    Watch video.
    Note:  To access this script, install the add-in at Collection: Interactive Teaching Modules.  As of JMP 12 you can also run these modules from Help > Sample Data (under Teaching Resources >Teaching Scripts > Interactive Teaching Modules). In JMP 12 Student Edition, you can run these modules directly from Help > Teaching Demos.
    Suggestions? Comments? Please reach out to JMP Academic's Mia Stephens or Julian Parris.
