Submit your abstract to the call for content for Discovery Summit Americas by April 23. Selected abstracts will be presented at Discovery Summit, Oct. 21- 24.
AFOTEC Conservative Power Tool for Test and Evaluation
This application changes the computation for effect power from a least to a most conservative estimation. It was designed to reduce risk, increase resources and allow for extra noise within a system under test. It will also allow for the generation of power curves (graphically displaying power as a function of signal to noise ratio (SNR)).
To see a complete brief of  the Air Force Operational Test and Evaluation Center background and use of this product look at the attached power point.
Comments
Would like to know about this tool
Just talked to Nicholas at a meeting.  Just send him a message through the Community for details after you download it, Preeta.
