Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
Fitting Curves to Non-Linear Data
See how to:
  • Understand curve terminologyy
    • Linear Regression Model
    • Curvilinear Regression Model
    • Non-linear model
  • Choose specialized JMP Models
    • Fit Curve Capability/Platform - Easy dialog with many useful models
    • Non-Linear Capability/Platform - All the knobs for tuning convergence to create more and more complex models than Fit Curve
    • Column Formula Plus Non-Linear Capability/Platform – Create custom models and then use Nonlinear platform to solve parameters
  • Build model using Fit Curve, where the curve shape is the response.
    • Fit a model to the time course data
    • Then use parameters for responses in the DOE model
  • Build model using Non-Linear specialized model
  • Build model using formula and Non-Linear specialized model combination
Questions answered by Byron @Byron_JMP  and Jerry @JerryFish  during the session.
Q: Is there a way to have a custom formula in the model library?
A: Yes, if you open Analyze/Specialized Models/Nonlinear, then click on Model Library, and you can enter your own formula.
Q: Can you get other metrics of model performance under nonlinear? I saw RSME and maybe one other.
A: Yes, see Non-Linear Platform options.
Q: Can add a callout box with the data in the box to each plot?
A: In Graph Builder you can use the Hover Label drill-down.
A: Is the large sample data available?
Q: Yes. Enzyme Modifier data is available.
Q: You mentioned Functional DOE for analyzing data that doesn’t have a good model.  Is that available?
A: Wavelets DOE is available in JMP Pro 17.
Resources
