This webinar is in English, 11:00 a.m. US Eastern Time.
This session is for JMP users who need to evaluate product reliability for parts that need to perform for long periods and can’t afford to wait for failures to occur at their normal rate.
The new JMP 18 Constant Stress Accelerated Lifetime Testing (Constant Stress ALT) special-purpose DOE capability lets you create and evaluate multi-factor designs for up to 3 acceleration factors and then use a JMP script to launch the Fit Life by X model after the data is collected.
The interface is easy to use to interactively identify factors and test conditions, specify planning values for the underlying acceleration model and automatically create three test plans: Optimal, Compromise, and Balanced.
JMP summarizes the modeling and design information for the Test Plans and gives Design Diagnostics for each plan. Diagnostics include statistics as well as three Profilers: Distribution, R-Precision Factor , and Model Sensitivity to help you choose your design(s) before creating the design with a simple button click.
One of the key JMP Developers will demonstrate and explain the capability. The session includes time for Q&A.
