Design of Experiments Example: A Mixture Design with Process Factors
marie_gaudard0
Staff (Retired)
In this example, you create a design for an experiment involving both mixture factors and process factors. The design is an 18-run design that is balanced with respect to the levels of a categorical factor. The design enables you to fit a full response surface. You use Design Evaluation plots and results to examine the relative prediction variance of the design.
