Filtering by Community Labels
Where available, you can select filters from Filter By on the right column.
The basic process for filtering  within an area of the Community is to select one or more filters, and then select the Apply button. Your screen will refresh with a list of the results from that Community area.
 When you filter by more than one option, you find only articles that meet a combination, or cross-section, of those options. For example, you might find articles with an Analytic Capability of Basic Data Analysis that are also in English.
 To start, highlight option(s) you want, then Apply. You can start with one or more options. If you add more options and then Apply, your list will refresh with articles that meet the latest selected options.
