This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customize your cookie settings.
JSL instruction to call script saved with data table?
May 30, 2014 12:00 PM(13422 views)
I'm trying to call a script saved with a data table from another JSL script. Is that possible? I've used Include() before to call a JSL file, but can't figure out how to call a script that is saved with a data table.
NamesDefaultToHere(1);
dt = Open("$SAMPLE_DATA/Big Class.JMP");
// Find out what scripts are stored
sl = dt << getTableScriptNames;
// Pick a script at random
s = sl[RandomInteger(1, NItems(sl))];
// Run it
s = dt << runScript(s);
// Get a reference to the analysis object
obj = Report(s) << getScriptableObject;
// Find out what messages this object understands
ShowProperties(obj);
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '8600' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if (newSub.getAttribute("slang").toLowerCase() == code_l.toLowerCase()) {
if (value == '8600') {
else{
} else {
sub_L = newSub.innerHTML;
try{
catch(e){
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
