lala
JSL Regular substitution: Replaces the same line | and the following characters with null
Such as
BPS<4.05|is Missing(BPS)
BPS>=2.75
ab>=1961734|is Missing(ab)
efg<13741
to
BPS<4.05
BPS>=2.75
ab>=1961734
efg<13741
Re: JSL Regular substitution: Replaces the same line | and the following characters with null
There isn't a need to use Regexes for this, Words + Word should be enough
mystr = "\[BPS<4.05|is Missing(BPS)
BPS>=2.75
efg<13741
mylist = Words(mystr, "\!N");
comparisons = Transform Each({line}, mylist,
	Word(1, line, "|");
result = Concat Items(comparisons, "\!N");
lala
  • I prefer to use regular.
BPS>=2.75
efg<13741
t1=Regex(mystr,"\|(.[^)]{0,})\)","",globalreplace);
It can also be a good option. Sometimes regex patterns are difficult to understand and you can end up with difficult patterns (especially if you have corner cases) but it is very flexible
View more...
rgx_parse = function({str}, {Default Local},
	// new_str = Regex(str, "\|.+?\)", "", GLOBALREPLACE);
	new_str = Regex(str, "\|(.[^)]{0,})\)", "", GLOBALREPLACE);
	return(new_str);
words_parse = function({str}, {Default Local},
	mylist = Words(str, "\!N");
		Word(1, line, "|");
mystr1 = "\[BPS<4.05|is Missing(BPS)
BPS>=2.75
efg<13741
mystr2 = "\[BPS<4.05|is Missing(BPS)
BPS>=2.75|
efg<13741
mystr3 = "\[BPS<4.05|is Missing(BPS)
BPS>=2.75|)abc
efg<13741
Show(rgx_parse(mystr1));
Show(words_parse(mystr1));
write("\!N");
Show(rgx_parse(mystr2));
Show(words_parse(mystr2));
write("\!N");
Show(rgx_parse(mystr3));
Show(words_parse(mystr3));
write("\!N");
