OleLuehn
JMP 18 Python pip install azure-kusto-data
Hi there.
I have a script in JMP 17 which worked pretty well - and now by changing to JMP 18 I get an error.
the log says the following.
Traceback (most recent call last):
File "<string>", line 7, in <module>
ModuleNotFoundError: No module named 'azure'
I use microsoft azure to prepare data evaluations and transfer it via python to JMP.
In the 17 version I needed to install a connection / kustoClient like this
azure-kusto-data · PyPI
How do I get this into the folder in JMP where the python package is set?
From the log I understand that the python 18 is not finding the azure "add-in" in the pyhton folder under JMP, while this
azure-kusto-data is install already on the python folder / not the one in JMP.
Maybe @Paul Nelson knows?
Re: JMP 18 Python pip install azure-kusto-data
JMP18 uses its own Python installation and you need to install the python packages separately for it. This help page should contain the information you need https://www.jmp.com/support/help/en/18.0/#page/jmp/install-a-python-package.shtml# (you need to use jpip).
OleLuehn
Hi Jarmo.
I try it. Thank you !
Ole
OleLuehn
Hi Jarmo.
Ole
