lala
Can JMP draw this kind of diagram?
I want JMP to do more.
Re: Can JMP draw this kind of diagram?
The text angle, size, and font are specified with the same function.The text angle, size, and font are specified with the same function.
8 REPLIES 8
I think you are asking two different questions:
  1. does JSL have drawing commands that are needed to make this picture? (yes)
  2. does JMP have a platform, or could JSL be written, to make the semantic information this diagram represents?
This particular diagram is pretty, but perfectly organized so it probably doesn't encode anything interesting; the outer ring just counts from 0 to 31 on the left and 32 to 63 on the right. The inner blocks count from 63 to 0 from top to bottom.
lala
I just want to make this form of graphics on the line, don't worry about the text ranking order.
This is 64 characters.
Thanks Experts!
lala
In order to make A simple picture, can you use the 25 letters A-Y to draw a similar picture with JSL?
The circle of the outer ring and the distribution of 5*5 in the middle.The order of the letters is unlimited.
This one can only be done with expert help.
A-Y
Thanks Experts!
You can. The inner square looks something like this
symbols = "abcdefghijklmnopqrstuvwxyz";
n = sqrt(25);
radius = sqrt(2) * n/2 + 2;
i = 0;
for(x=1, x<=n, x+=1,
   for(y=1, y<=n, y+=1,
      i += 1;
      sym = substring(symbols, i, 1);
// - n/2 centers the x and y about 0,
// adding radius moves the center text( { x - n/2 + radius, y - n/2 + radius }, sym ); ) )
The outer ring looks something like this
for(i = 0, i<25, i+=1,
   sym = substr(symbols,i+1, 1)
   fraction = i / 25; // 0 <= fraction < 1
   x = radius * cos( fraction * 2 * pi() ); // cos and sin make unit circle
   y =  radius * sin( fraction * 2 * pi() ); // coordinates, then scale with radius
// the scripting index has an example that rotates the text
   text( { x + radius, y + radius }, sym )
This assumes you'll make a graph with axes from 0 to 2*radius and you'll adjust the font size and you'll put this in the graphics script.
lala
Thank Craige!
substring?
Did not pass.
lala
I searched for rotates the text, only found this, not yet understand how to apply.
Thanks Experts!
lala
I SEE
Thanks Experts!
