The acceptance sampling plan add-in provides a point-and-click interface for generating / creating, evaluating and comparing sampling plans.
Specifically, one can create sampling plans by lot acceptance sampling by attributes and variables acceptance sampling. Attribute sampling plans supported include:
- Single
- Zero ( C = 0, Squegila Plans )
Variable sampling plans supported include:
- Sampling by Variables for proportion nonconforming
Key features:
- Generate / Create sampling plans
- Evaluate sampling plans
- Compare up to 5 sampling plans
- Operating Characteristic ( OC ) Curves
- Acceptance Region Plot
- K-Method for variables sampling plans
- One-sided spec limits
- Two-sided spec limits
- Generate variables collection table for analysis with unknown standard deviation
- Validation / Integration test cases
- Performance measures for Average Outgoing Quality (AOQ) and Average Total Inspection (ATI)
- Acceptance region
Acceptance Region Plot with summary
Installation:
Click the link above to download the add-in, then drag onto JMP to install or double-click the add-in to install.
Give it a try and be sure to reply and leave comments below.
Version: Initial beta release
Minimum JMP Version: 14
Basic usage:
Launch add-in from JMP Add-ins menu
Select JMP Sampling Plans from the Menu
JMP Sampling Plan Add-In Menu options
Select Attribute or Variables Sampling Plans to launch sampling plans menu
Single Attribute Sampling Plan Dialog Options
Options Menu for modifying default options and for launching integration test cases or validation test cases
Options Menu
Example Output:
Performance Measure Graphs including AOQ and ATISampling Plan Tabular Summary
Comparing Sampling Plans
Known Issues:
- Single Attribute Sampling using Verification and Validation ( V&V ) ( planned for next update )
- Double Sampling Plans ( planned for future update )
- Sampling by variables for proportion nonconforming using Verification and Validation (V&V) ( planned for next update )
- Help documentation incomplete
Change Log:
November 4, 2020: Version 1.01
- Updated the minimum JMP version supported to 14.
- Removed startup script
March 2, 2021: Version 1.1
- Bug fixes
- Evaluation of double sampling by attributes
- Average Sample Number (ASN Curve)
- ASN and ASN_c ( fully curtailed )
31 March 2021: Version 1.3
- Bug fixes
- Preferences file located in USER_APPDATA by default
- Unit test cases / validation test cases located in USER_APPDATA by default
21 July 2021:Version 1.4
- Bug fixes
- Fixed issue with error related to ::_lotacc_val_ not found
6 March 2023: Version 1.6
I have written the first in a series of blog posts related to acceptance sampling by attributes, zero acceptance sampling plans, variables sampling plans and double sampling by attributes. What is Acceptance Sampling?
Review the sampling plan add-in by using the QR Code
Rate the JMP Sampling Plan add-in
